pugetsounder
Advanced Contributor
"OK so this is a continueum of
"OK so this is a continueum of this thread:
http://www.marineengine.com/discus/messages/12487/81339.shtml
Please have a little patience with me I am slowly working out the bugs in my boat.
OK friday night took it out for another test run. This is after I decided to re-tune the motor. Never assume anything as I bought the boat from a self proclaimed mechanic that said he did a complete tune-up on it. I rechecked the points: They were opening three times wider than spec'd, reset them to 0.016". Checked the timing: It was 15 degrees too far advanced, reset to 6 degrees BTDC. Checked the carbs with my Uni-sync tool. One air screw was 2 1/2 turns out the other was 5. Reset them.
OK so I have a three main problems since then. One is hard starting. It cranks over for a long time and I have to give WOT to get it to start. Once started it seems fine and I can keep it running. No problems idling at this point. Let it warm up and off we go. We jet across Elliot Bay for dinner, it's about two miles across. It ran great, smooth and no hesitations. Second problem, I slowed down to enter the marina, then it had a hard time idling. It seems to be missing and not a smooth idle like before. I have to run it at 1500 rpms through the marina to keep it running much to the dislike of people having dinner on moored their boats. So we pick up some friends for a run around the bay. It starts up OK, but the idle is still an issue. The thrid problem happened when we hit the open water again. She runs good, gets on a plane easy even with four poeple, then after a few minutes it seems like it wants to die. We slow and I have very little throttle response from the motor. It will idle but sure seems like it wants to die. I even get a pop out of the engine which freaked one of my passengers out. So I decide we should head for the dock and we can only get very little speed out of the boat the throttle at wide open just isn't responding the engine won't rev. After a few minutes of this and playing with the throttle back and forth finally it's like something catches and it takes off. We dropped our friends at the dock and took off for home and had no problems all the way back. But still when we got to the launch I still had the idling issue where it won't idle smooth and seems like it's missing at idle until I bump the throttle up a little. I think I'll bump up the idle this may take care of that problem as when it's completely warm and on the water it idles at 700 RPM but in my driveway and on the hose it idles at a perfect 900 RPM.
The tank of gas is only a couple months old. I added some fuel stabilizer, HEET fuel anti-freeze, and STP carb clenaer to it when I filled it. The filter was fairly clean but looking closer there was a little residue that disappeared when I shook it. My feeling is that it's fuel related but not sure. If it was intermitten like that wuld it mean the carbs need rebuilding? The biggest problem is that it's intermitten and doesn't happen all the time. It worries me because I don't want to be too far from home until I get the intermitten problem worked out. My wife is anxious to go for a nice long sunday boat ride but I'm afraid of getting more than a mile or two from the launch."
