"My motor is not peeing water.
"My motor is not peeing water. I have removed the lower unit and removed the 4 bolts off the pump, how do I remove the impeller from the shaft? I purchased a new impeller to install.
Also, I have blown/flushed out the water line to see if any clogs, which there were not. However, upon visual inspection, the impeller looks fine (I have not removed it). Would there be any other reason that the motor would not be spitting?
Any help will be greatly appreciated."
