Omc engine rotation GM 305 50L
aquahaulic
"Could anyone tell me if the r
"Could anyone tell me if the rotation of the GM engines change. Im told that it is only the ford engines that had different rotations, I know some engines have different firing order, If i get a engine for my boat does it have to be the same firing order for it to work."
"G.M.engines came in both flav
"G.M.engines came in both flavors. all sterndrives use left hand rotation. (flywheel counter-clockwise, from rear) firing order unimportant. rotation very important."
i have a omc stringer 800. so
i have a omc stringer 800. so if i find a 5.0L that is in a boat with a omc outdrive it will work no matter the firing order
"ford, gm would have different
"ford, gm would have different flywheel housing bolt patterns. but gm to gm will work."
