30 gamefisher questionsPLEASE HELP
E
EDWIN6279
Guest
" TOOK OFF THE CARB, PROPERLY
" TOOK OFF THE CARB, PROPERLY TOOK IT APART, DIPPED IT IN THE CLEANING SOLUTION, PUT IT BACK TOGETHER AND NOW IM HAVING PROBLEMS GETTING IT STARTED. IT WAS STARTING FINE. ALSO WOULD LIKE TO FIND OUT WHAT YEAR IT IS..IM GETTING ALL MY PARTS FROM SEARS, BUT THEY DO NOT KNOW THE YEAR. "
" Just dipping a carb in clean
" Just dipping a carb in cleaner will not clean it properly. You need to use compressed air to clean passages, jets etc. If you post the serial/model number one of the board gurus might be able to help with year....? "
