Page 6 of 6 FirstFirst ... 456
Results 151 to 164 of 164
  1. #151
    Default Re: Montgomery Ward Sea King 5
    i have a sea king 5 model# gg18801a I would like to know what year it is. I am pretty sure it is a gale because of gg in model number
  2. #152
    sea king 3.5 outboard the gas ratio is sae#30 or 40 1/2pt for every gallon according to my motor its a 1966
  3. #153
    Default Re: I've got 1 45GG-9015A I&#3
    I have the complete 35GG9015A owners manual. You are welcome to a copy. I am looking for a copy of the model 45GG-9015A serial # 529731 motor. I am getting ready to replace the water pump impellor and repair the damage after my sister set it on fire (she did now understand the function of the prime). She left it on flooded the motor, half of Lake St. Clair, and the stern of the boat. They had to abandon ship and fight the fire from the water. Our father had just asked me to tune the motor and I took it home to do same. I was assembling the necessary parts when she called up and said something to the effect like: "Dad says you have the motor and he said I can borrow it when you are done fixing it". I told her that I was still buying parts and that it just barely runs and not to use it because you might get stranded. Well she came by one day when I was not home. took it...well you know the story. Sadly our father died before I have finished the project. I would really like a repair manual before going into the lower end. I can be reached at [email protected]
  4. #154
    motor won't run smooth ? won't start after setting all winter ? needs to be choked to run ? ...clean the carb . take it apart and lay the parts out on something clean ... then clean the parts with lacquer thinner .. it cuts gunk very well and very quick. ream out jets and passages with "tip cleaners" (they are what is used to clean out gas cutting torches and brassing tips) the tip cleaner sets are cheap and have a file on each size rod ... 90 % of the time a good cleaning will solve the above problems.......
  5. #155
    I was replacing the coils, points, and condensers on my 45GG motor and I did a dumb thing. I disconnected all. I am wondering...Does each coil need to be connected to a specific pair of points and condensers of does it matter? I can be reached directly at [email protected]
  6. #156
    Default Re: "I have a 45gg-9015a mongomery
    @ Mikcha61. I have reprints of the 15, 35, & 45 GG models. I also have reprints of the parts and repair manual for the 15 GG model. I can be reached at [email protected] or on eBay as donparadowski. By the way, I have been searching for the description of part # 200-322 as well as 202-111, and 202-114 in order to update my 15 GG parts and repair manual.
  7. #157
    I have solved the mystery of which point set goes to which coil. As you are looking at the motor as mounted on the transom of a boat the points that go to a coil is to the right of that coil.
  8. #158
    Default Re: "35GG9015A Looks to be a 1953
    i have a 1950 5hp sea king went through the carb and just about everything else minus the cylinders seems to hav no spark...not sure how to go about disassmbling and fixing
  9. #159
    Quote Originally Posted by gkennedy87 View Post
    Did you check the points and condenser? Also take a look at the two mag coils. If they are cracked...replace them. Lastly what shape are the plug wires in?
  10. #160
    Quote Originally Posted by donparadowski View Post
    I forgot to mention if you want to change the points and condensers you can do that through the oval hole in the top of the flywheel. If you need to change the mags you will need to remove the flywheel to do that. It requires 46 foot pounds of torque to reset it properly.
  11. #161
    Default Re: Where is the water pump locate
    Quote Originally Posted by sandmanwv View Post
    Where is the water pump located?? I took 4 bolts out of the bottom and there was oil and a shaft but no impeller.
    Up higher.
  12. #162
    Default Re: Hopefully someone else can exp
    from what ive found out, the 9015A has a neutral lever, where the 9014A does not
  13. #163
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,747
    Carl that thread is from 4-28-16
  14. #164
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    2,747
    I don't know if anyone has followed this thread if you possibly could,what a mess. no hijacking here
Similar Threads
  1. Montgomery Ward Sea King 5
    By sandmanwv in forum Gale Outboards
    Last Post: 08-19-2010, 01:05 PM
  2. 5hp Sea King Montgomery Ward
    By riboater in forum Gale Outboards
    Last Post: 07-11-2010, 09:06 AM
  3. Help with Sea King 152 Montgomery Ward
    By wwells in forum Montgomery Wards Sea King
    Last Post: 11-05-2009, 04:01 AM
  4. 5hp Sea King Montgomery Ward
    By spankky in forum Montgomery Wards Sea King
    Last Post: 09-16-2009, 09:22 AM
  5. Montgomery Ward Sea King
    By Chris Fara in forum Archive 2003-2009
    Last Post: 06-10-2008, 05:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
