Results 1 to 3 of 3
  1. #1
    Join Date
    May 2007
    Location
    Roanoke Rapids, North Carolina, United States
    Posts
    12
    Default "I need help please,I have got
    "I need help please,I have got my outdrive off,I took the shift cable assembly off of top of bellhousing planning on taking that out with outdrive so i dont have to disassemble,But the STEERING CABLE is the only thing holding me up from completely removing it i took the outdrive off by removing 13 or so small nuts around back of bellhousing i have to replace 22 hole transom seal and also why ive got it off is it easier to replace water impeller if so i'll do that while it is off and do i have to replace complete gasket set for upper unit to replace water pump kit it is a 1986 stringer 800 omc this is my first time so i would be greatful for any help"
  2. #2
    Join Date
    May 2006
    Location
    Posts
    136
    Default "You don't have to buy a c
    "You don't have to buy a complete upper seal kit to do the water pump. The pump kit comes with all you need. I would go a step further and buy the kit with the pump housing. It is easier doing the pump with the drive off the boat and its not too complicated. I removed the small bolts holding the top cover of the upper unit, I popped it off and just lifted the upper out of the lower. No need to remove the whole lower drive from the case. The thing is the shift cable also goes through the upper unit so you will have to make some slack in it. I too was going to do what you did and leave the cable intact in the shift box but I didn't need to pull the intemediate (IM) and if you don't you cannot get the box out the transom hole. Not enough clearance with the IM in. I just disconnected it. It ought to be fun putting it together but I took digital pics. Having the shift cable completely out of the way helps a lot. You may want to reconsider. It is a bitch removing it from the IM, its in there tight."
  3. #3
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default The steering cable has nothing
    The steering cable has nothing to do with removing the outdrive.
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
Similar Threads
  1. How to remove stringer engine without removing drive
    By chiefalen in forum OMC Sterndrive and Inboard Forum
    Last Post: 12-11-2009, 07:02 PM
  2. Anyone looking for a 800 Stringer Outdrive
    By edjunior in forum OMC Sterndrive and Inboard Archive
    Last Post: 02-24-2009, 08:46 PM
  3. Removing shift cable from stringer sterndrive 800
    By aquahaulic in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-07-2007, 10:48 AM
  4. Removing steering cable from stringer sterndrive 800
    Last Post: 06-02-2007, 09:45 PM
  5. Buying new stringer outdrive need help
    By Tyler Maniez in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-30-2007, 05:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
