friendship_ii
"Hello,
I have a 1936 classic
"Hello,
I have a 1936 classic cruiser. I run a 1949 Chrysler Crown 110. It was last overhauled in 1983. Although the motor has run fine since we purchased the boat 4 years ago (knock on wood), it is showing signs of wear. We are looking to rebuild or replace while we are in the position to do it on our terms--not having to haul it or tow it to a boat yard becuase the engine went.
As you know, the engine is a HUGE beast. To rebuild, we will have to tear the cabin apart to get it back in. If we replace it with a new/newer engine, we can take the motor apart where it sits, and easily put in a newer, smaller motor without as much cabin work. (Parts availability is a concern.) A new engine comes with the task of a custom exhaust, transmission, shaft, etc. Since the boat won't go more than 8 knots because it is a brick in the water, I imagine we can get away with a relatively small engine. I would prefer gas, since all around the costs will be cheaper. I am in the Seattle area.
Any and all comments and advice are appreciated."
"Hello,
