R
rich b
Guest
"i have a 1971 searay 22'
"i have a 1971 searay 22' - 165hp straight 6cyl.i have replaced all gauges and put in a new fuse panel and all old wiring looks good up front.connected what wires went to what gauge when i took old one gauge out.tach wont work-key switch problems.1st click on key i have power to coil then when i turn it to start,starter turns over but no power to coil then as the key is comes back to the first postion the motor fires up.i have new-starter-starter solenoid-coil-wires-plugs.boat started fine last weekend.this weekend i was stranded.check wiring harness back to motor and everything fine.bought a clymers mercruiser repair manual for 75.00 to check wiring.and all my wires on the motor are backwards from the book.can anybody give me a wiring diagram of how everything goes on the motor and instrament panel.the person before me used wire nuts on wiring.hahahaha the repair manual doesnt even come close to where the wires go.please help.i want to re wire entire boat.cant be that hard.5 gauges-starter-starter solenoid-coil-distributor with points and condensor-alternator thats about it.can some one draw me a diagram.any thing will help.thank you"
