Results 1 to 3 of 3
  1. #1
    W Bunch's Avatar
    W Bunch Guest
    Default "Mercruiser 4.3Lx stalls under
    "Mercruiser 4.3Lx stalls under heavy acceleration, at rpm 4000 or more. Could it be the electric fuel pump? If so, how do you check the pressure and what should the pressure be?"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default When is the last time ALL OF T
    When is the last time ALL OF THE FUEL FILTERS were serviced. Plugged filters act like a dying pump. Start there since that is the cheapest route and see if it improves.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default u need a fuel pressure gauge
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
Similar Threads
  1. Mercruiser 43LX Loss of Power
    By chad2021 in forum Mercruiser Sterndrive Archive
    Last Post: 06-22-2009, 09:52 AM
  2. 01 DT 140 stalls under acceleration
    By John Almeida in forum Suzuki Outboard Archive
    Last Post: 08-25-2008, 09:16 PM
  3. Evinrude Intruder 150 stalls on acceleration help
    By a33god in forum Johnson Evinrude Outboard Archive
    Last Post: 08-18-2008, 06:17 PM
  4. 1955 KBL stalls on acceleration
    By jlash in forum Chris Craft Engine Forum
    Last Post: 10-25-2007, 09:47 AM
  5. Replies: 1
    Last Post: 11-13-2002, 08:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
