Page 1 of 2 12 LastLast
Results 1 to 30 of 39
  1. #1
    Randall B's Avatar
    Randall B Guest
    Default "Just bought a boat with a kic
    "Just bought a boat with a kicker motor that the guy said was a chrysler. The model serial plate says Wards, Seaking 15 is on the Cowl? Which is right? are they all right?
    Model number is listed as VWB 52122
    The serial Number is 58X 3319
    It is running pretty rough right now but the gas mix was looking way too heavy. I am thinking it needs to be 50:1 I am guessing the year as late 70's to the early 80's? Any advice appreciated as to Where to find parts manuals etc.... Heck even to just know what it is?"
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default "Both are right - Wards/Chrysl
    "Both are right - Wards/Chrysler is all the same, just a different marketing name. I'll dig a bit for you and see if I can find a year to go with your model/serial numbers...."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "One more note to add, Chrysle
    "One more note to add, Chrysler build these between 74 - 78 for Montgomery Wards. Earlier versions were built by Clinton engines. So I'm digging in "two different holes" for find which model you have..."
    Graham
  4. #4
    Default Thanks so much. had a local
    Thanks so much.
    had a local mechanic tell me it was made by US marine in 84? I have never heard of US marine?
    I ran a half a tank of gas mixed with quickleen through it in a tank in my garage. seemed to improve things a bit.
    Went fishing this weekend and it failed to start out on the lake.
  5. #5
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "U.S. Marine was a division of
    "U.S. Marine was a division of the Brunswick Corporation. Aside from making pool tables they own a whole pile of Marine brand names including Mercury and Sea Ray to name just a couple. You will run accross a number of controls, gauges etc bearing the name U.S. Marine and were used with a very wide spectrum of products."
    Graham
  6. #6
    Default does this mean i can get servi
    does this mean i can get service info through Mercury ?
  7. #7
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "No - Mercury and Chrysler nev
    "No - Mercury and Chrysler never really had any kind working relationship. The budget line of FORCE motors (From Old Recycled Chrysler Engines) [img][/img] built by, and now orphaned and unsupported by Merc are a prime example. There are quite a number of SeaKing motors still out there, with alot of enthusiasts. Your best bet for support/information may be to do a web search for such a group and get connected with them. My interest in these type of old outboards stops with compiling model/serial lists to assist in identification..."
    Graham
  8. #8
    Default "Your motor is acually a 1985,
    "Your motor is acually a 1985, made by U.S.Marine"
  9. #9
    Mark Haag's Avatar
    Mark Haag Guest
    Default "I have a Sea King 50 hp outbo
    "I have a Sea King 50 hp outboard with serial #10537
    and model # VWB 19092. I would like to know the
    yr. and make of this motor and where I might be able
    to find parts, manuels and any other history. Thank you."
  10. #10
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "Mark, that is a 1964, twin cy
    "Mark, that is a 1964, twin cylinder, 50 horse built by Chrysler for Montgomery Wards and sold under their brand name.
    Despite it being dressed as a "Sea King", it is very much a Chrysler. Any Chrysler manual covering that model year will work for that motor.
    As to parts - Chrysler is long gone, parts are getting scarce. Depending what you need, Andrew who runs this site carries aftermarket parts for some applications. Otherwise, you need to do websearches.
    I do have a couple of sources for Chrysler parts, depending what you may be after...."
    Graham
  11. #11
    j martin's Avatar
    j martin Guest
    Default I have a 15hp Montgomerey Ward
    I have a 15hp Montgomerey Ward Sea King with a broken prop. The model # is vwb521191. The seriel # is 48x32565. Would like to know the year of motor and where to find a used or new prop. Any help would be greatly appreciated. Thanks
  12. #12
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "It looks like you have an ext
    "It looks like you have an extra digit in the model number.
    The VWB 52119 (either blank (79) or followed by an A thru E - A=80, B=81 etc) were 15 horse motors built by Chrylser between 1979 and up until 1984 (when Crysler was bought out by Bayliner).
    So essentially you have a 15 horse Chrysler. They have no dealer support at all anymore so for a prop you will have to look to aftermarket companies (such as Michigan Wheel sold at most marine places like WestMarine etc) or watch Ebay for someone selling a good used one..."
    Graham
  13. #13
    JMartin's Avatar
    JMartin Guest
    Default Thanks for the info this gets
    Thanks for the info this gets me heading in the
    right direction. Great website. Thanks again.
  14. #14
    brandon armstrong's Avatar
    brandon armstrong Guest
    Default i have a 15 horse mongomery wa
    i have a 15 horse mongomery ward sea king mod # vwb52115 ser# 57x20980 trying to find out what year the motor is and if anybody knows where i may be able to get a repair manual i bought it and it was all tore apart. would like to know if i could maybe put an electric start on it also
  15. #15
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "Brandon, what you have there
    "Brandon, what you have there is a 1975 Chrysler, so a Seloc's manual covering that time frame/hp will work well for you.
    Parts may be a little more difficult to come by for converting to electric start. Since Chrysler is long out of business you will have to first determine what you need and then watch recyclers/ebay and the like...."
    Graham
  16. #16
    Default thank you is there anyone that
    thank you is there anyone that might be able to work on it any dealers maybe i live in illinois
    not sure what do do
  17. #17
    Steve Jones's Avatar
    Steve Jones Guest
    Default I have a Chrysler SeaKing 15 h
    I have a Chrysler SeaKing 15 hp motor. Can anyone tell me the oil/fuel mixture rate for this motor?
  18. #18
    wade miner's Avatar
    wade miner Guest
    Default "I just bought a 15 hp montgom
    "I just bought a 15 hp montgomery ward.
    MOD: VWB 52115, S/N: 57X20501
    Can anyone tell me the year and what parts/repair manuals cover this?
    Also wondering what the correct fuel/oil mixture is?"
  19. #19
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default Wade you have a 1975 Chrysler
    Wade you have a 1975 Chrysler built for Wards. Any aftermarket maint manual for Chryslers of that vintage will work fine.
    Both you and Steve can mix at 50:1 with regular unleaded gas and TCW-3 rated Marine 2 cycle oil.
    You may want to replace the gas hoses under the hood if they are original - modern gas with alcohol/ethanol/methanol blends doesn't agree with the rubber in the older hoses - a couple bucks worth of gas line from any auto parts place can save you alot of headaches...
    Graham
  20. #20
    wade miner's Avatar
    wade miner Guest
    Default Thanks for the information. No
    Thanks for the information. Now I'll see if I can make it to the water this weekend!
  21. #21
    Join Date
    Apr 2008
    Location
    Mineral Wells, Tx, US
    Posts
    5
    Default I need a blow apart of a 15hp
    I need a blow apart of a 15hp Chrysler motor. I am trying to figure out how to remove the shaft to replace the water pump impeller. Or can someone tell me what I have to take loose to get the shaft out?
  22. #22
    Al   P 's Avatar
    Al P Guest
    Default "Hi everyone,I'm trying to
    "Hi everyone,I'm trying to find a cowl cover for my 1981 Montgomery ward 15hp chrysler sea king and also motor tiller control.Does anyone have any idea where i can get these parts? Thanks guys....."
  23. #23
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "Al, try [url=""]www.twincityo
    "Al, try www.twincityoutboards.com - get ahold of them there. They are a little pricey as far as recylers go, but the literally have "everything"..."
    Graham
  24. #24
    Al  P's Avatar
    Al P Guest
    Default "Graham,Thanks for information
    "Graham,Thanks for information.}"
  25. #25
    Chad Sanders's Avatar
    Chad Sanders Guest
    Default "hello, I am needing assistanc
    "hello, I am needing assistance, I have a late model Sea King made by Montgomery Wards that somewhere in the Late 60's. This is my first outboard motor and need help. What is the gas/oil mixture do I need to use in a 6gallon gas tank. My outboard is a 12.o hp the Model # is GG8971A serial # 75X692611 if someone could help me I would appreciate it tremendously"
  26. #26
    Join Date
    Apr 2008
    Location
    Posts
    5
    Default I am looking for a recoil mech
    I am looking for a recoil mechanism for a 15hp Chrysler. The one that was on the motor had been taken off befor I got it. Please contact me a my email.
  27. #27
    Join Date
    Jun 2009
    Location
    Orange, Ma, USA
    Posts
    2
    Default I have a sea king 15 HP outboa
    I have a sea king 15 HP outboard and 1 plug wire came unattached from the grommet that fits over the plug.. Where can I find a replacement plug wire for this?? The model number is VWB 52122. Any help would be great. Mark
  28. #28
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default "That engine took solid core w
    "That engine took solid core wire (available by the foot from Napa) and you should be able to just trim about 1/2 inch off and screw it back on the post. If it pulled from the spark plug connector,you will need to get the wire wound connector out of the rubber boot with wd-40 and a needle nose plyers. Then straighten out the stabber so it is pointing at the wire and stab the wire and slide it all back into the boot."
  29. #29
    Join Date
    Jun 2009
    Location
    Orange, Ma, USA
    Posts
    2
    Default Thanks alot!! I will try it. M
    Thanks alot!! I will try it. Mark
  30. #30
    Join Date
    Jun 2009
    Location
    Corvallis, or, us
    Posts
    2
    Default I have a 79 sea king 15 VWB521
    I have a 79 sea king 15 VWB52119. does somebody know of a surce for props? I have tried TC. franzmarine.com does not come up. nothing on ebay. I am looking for a spare so I can run the river.
Similar Threads
  1. 1948 Wards SeaKing 5hp 84GG9014A Manual needed
    By danielb1 in forum Montgomery Wards Sea King
    Last Post: 05-08-2010, 03:45 PM
  2. Seaking, Eska, Gale, Wards, etc.............
    By majkmann in forum Gale Outboards
    Last Post: 04-18-2010, 11:25 PM
  3. Wards 1972 96hp seaking
    By ts7424 in forum Montgomery Wards Sea King
    Last Post: 09-16-2009, 09:27 AM
  4. 35 hp wards seaking
    By anklegravy in forum Johnson Evinrude Outboard Archive
    Last Post: 07-30-2009, 03:19 PM
  5. 1972 96hp wards seaking VWB27209
    By ts7424 in forum Chrysler Force Outboard Forum
    Last Post: 07-20-2009, 10:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
