LIVEWELL PROBLEMS
carlnap
I've noticed that my live
I've noticed that my live well is filling up at half the rate. The pump sounds good. Is there a filter that gets changed or maybe at the intake the screen can be clogged.
"Look for a kink or crack in t
"Look for a kink or crack in the fill hose in the lowest spot & at any connecting points(if bilge is slowly flooding), intake screen clogged with algae, moss or plastic wrapper, and finally check the spray head in the livewell for algae or debris plugging it.
All points clear of debris and no hose crack, then pump is failing or impeller may have fishing line or stringy debris wrapped around it which requires removal of the pump to inspect it.
Guy"
