Changing water pump impellers
B
Boca Rick
Guest
How long should it take to cha
How long should it take to change the inpellers in the water pump on a merc 350 horizon engine?
"Boca Rick:
Do you want it
"Boca Rick:
Do you want it done right with an inspection of the other visible outdrive parts? If yes, then as long as it takes. I'm an old man with one foot in the grave and the other on a bananna peel and it takes me a couple of hours if all goes well but I am sure any experienced mech. can do it in less time.
Guy"
"Rick;
Guy is right, it shoul
"Rick;
Guy is right, it should not take more than a couple of hours, including R & R the lower gear case. There is no reason to remove the whole drive leg unless you also want to inspect the U joints, gimbal bearing, bellows etc at the same time.
If you are handy at all, it requires no special tools or skills. You can do it yourself.
Rod"
