Results 1 to 8 of 8
  1. #1
    Join Date
    Feb 2007
    Location
    Pelican Lake, WI, usa
    Posts
    30
    Default I bought a used outdrive of eb
    I bought a used outdrive of ebay. I did a pressure test before installing it and I relized there is a leak where the spline shaft comes out of the outdrive. Is this something I can repair myself? Or do I need to bring it in??
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "Dave: How much pressure did
    "Dave: How much pressure did you use? Only need a hand bicycle pump. Anything more will cause a leak.
    If it's leaking at the prop spline, there are two shaft seals back-to-back that you can replace. They require loctite to install them.
    Guy"
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Feb 2007
    Location
    Posts
    30
    Default I only used 5 psi. The leak is
    I only used 5 psi. The leak is on the top of the lower unit. where the splined shaft comes out of the outdrive. When I opened up the box from ups I noticed the oil that leaked out of it. Is this something I am capable of fixing???
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "Dave: I don't know you
    "Dave:
    I don't know your abilities but suggest that you read up on the replacement procedure before deciding either way. I have never done it.
    Looking at a parts blowup it appears that the u-joint and shaft assy. have to be removed first and then the retainer, spacer, o-ring and then the oil seal.
    Perhaps one of the other members can guide you through the process or advise to have it done.
    I would at least look at the water impeller and probably replace it since it is apart. If the impeller housing appears to have been overheated (melted), replace both the upper and lower impeller housings; the lower has an oil seal for the bottom of the vertical shaft.
    Guy"
  5. #5
    Join Date
    Aug 2006
    Location
    Calgary, Alberta, Canada
    Posts
    2,426
    Default "You need a special wrench to
    "You need a special wrench to loosen and re-torque the retaining nut PN 816811-1 that screws into the housing and holds it all together. Other than that it is all doable without difficulty. Make sure you put the same shims back in exactly where they came from, as these set the gear mesh.
    Rod"
  6. #6
    Join Date
    Apr 2004
    Location
    Posts
    237
    Default I would recommend that you hav
    I would recommend that you have the entire drive resealed professionally. This is a good time to ensure that you used drive is in good shape before you put it on the boat and risk getting standed or worse sunk.
  7. #7
    Join Date
    Feb 2007
    Location
    Posts
    30
    Default "I made a wrench to get the re
    "I made a wrench to get the retaining nut off. When your taking it apart do you just take out the shaft, yoke, untill you get to the 2 oil seals, or do you have to pull out everything- bearings,spacers,everything up to the gear and nut on the end. Thanks for all the help I would be lost without this website. Dave"
  8. #8
    Join Date
    Aug 2006
    Location
    Posts
    2,426
    Default The whole assembly comes out i
    The whole assembly comes out in one piece including the drive gear and retaining nut. Then you can dissassemble it on the bench to change the seals. Note that there is a specified torgue value for the gear nut (in order to preload the bearings) and also for the retainer nut when you re-install it all back in the drive.
    You really should get yorself a Seloc or Clymer manual to get all the info you need to do this job right.
    Rod
Similar Threads
  1. Water tube seal leaking
    By dcbullington in forum Mercury Mariner Outboard Forum
    Last Post: 07-07-2010, 09:51 AM
  2. Leaking Mercruiser 57 Alpha 1 Sterndrive
    By clintonnz in forum Mercruiser Sterndrive Archive
    Last Post: 02-23-2009, 06:01 AM
  3. Leaking seal and need to replace it on a 671 N Pump
    By johny74 in forum Detroit Diesel
    Last Post: 06-28-2008, 12:46 PM
  4. Reverse rotation leaking seal
    By shuffster in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 07-25-2007, 01:20 PM
  5. 1988 cobra 75 sterndrive madalion seal
    By tvwbug in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-18-2006, 07:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
