Results 1 to 3 of 3
  1. #1
    Join Date
    Mar 2007
    Location
    cape canaveral, Fl, usa
    Posts
    6
    Default "Does anyone know how to clean
    "Does anyone know how to clean the rust and trash from a 250 Gal fuel tank, without having to remove it. Yes I have cleaned all of the filters"
  2. #2
    Default Maybe thru prayer? Your tank
    Maybe thru prayer? Your tank will more than likely have to come out......I had a 130 gallon tank with the same problem on my SeaRay....I tried draining and vaccuming and even tried gas tank sealer to no avail.....When they get that bad its time to replace...
  3. #3
    Join Date
    Jul 2007
    Location
    Posts
    376
    Default what about prayer and money. t
    what about prayer and money. that might help speed the tanks miraculous recovery.
    Bass Slayer: 1990 Tracker Deep V 16
    40 hp Johnson- TJ40ELESR
    Blue Water Led Bow and Deck lighting
Similar Threads
  1. Trash in carbs
    By bw94 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-30-2009, 05:13 PM
  2. Trash in carb
    By harleylarry in forum Mercury Mariner Outboard Archive
    Last Post: 03-27-2008, 06:47 PM
  3. Trash Can full of antifreeze
    By Dino Fanetti in forum Volvo Penta Gas Archive
    Last Post: 10-26-2007, 04:11 PM
  4. Plastic fuel tank rubber fuel lines amp grounding
    By cwebb in forum Archive 2003-2007
    Last Post: 12-02-2006, 11:50 PM
  5. I have a 1949 montgomery wardssea king should I rebuild or trash
    By bassmaster1234 in forum Archive 2003-2009
    Last Post: 09-03-2006, 12:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
