I have a 1995 Johnson 50hp mod
I have a 1995 Johnson 50hp model J5BELEOD that I am concerned may be running to lean. I pulled the plugs out after about an hour of use on new champion QL78YC plugs. The top plug had a yellowish color to it with no signs of blackness or oil on it. The bottom plug was pretty much clean with a little bit of black around the middle. Maybe I'm just used to older 2 strokes that always turned the plug black almost right away. How would I go about adjusting these carbs to run a little richer?
