"Hi,
Would rev limit cause th
"Hi,
Would rev limit cause the engine to run richer and foul plugs faster ?
My tell tale is too hot to keep your hand under and may be the cause of the rev limit.
Also, I acidently mixed synthetic two stroke oil with standard oil, could that cause excessive fouling ?
I have 4 very wet brown looking plugs after two short runs, then it won't start or run until I change or clean the plugs. The engine has good compression in all cyl.
I measured 9VAC on the send wire to the tach from the coil, spark seems very strong."
"Hi,
