Results 1 to 8 of 8
  1. #1
    Jason U's Avatar
    Jason U Guest
    Default "Hi all, Just have a ques
    "Hi all,
    Just have a question to anyone who may be able to offer advice.
    I have a 2006 Johnson 150 HP 2 stroke OB. Recently, while running only in idle or in gear at very low RPM (barely making steerage), my no oil alarm suddenly comes on. It has happened 4-5 times. There is pleny of oil in the tank. I disconnected the oil hose from the VRO, pumped the bulb and plenty of oil came out, so the pump is getting oil. But, even after doing that, I got the same alarm twice the next day while on the water. Any suggestions would be much appreciated!!
    Jason,.."
  2. #2
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "my only suggestion,on that ne
    "my only suggestion,on that new of an eng,is dont even worry about it,take it in for warranty work...."
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,309
    Default Just exactly what did that ala
    Just exactly what did that alarm sound like?
    We occasionally have questions. If you fail to answer, it may affect ours.
  4. #4
    Jason U's Avatar
    Jason U Guest
    Default "I will probably take it to a
    "I will probably take it to a dealer, but thought I would get some insight from others who are more knowledgable first.
    Joe, it is a high pitched tone. It goes on for about 5 seconds, then off for 1-2 minutes, then on for 5 seconds again. I can get it to stop by stopping and restarting the engine, but it will soon sound again.
    jason"
  5. #5
    Join Date
    Feb 2001
    Location
    Posts
    14,309
    Default "That's a new one on me Ja
    "That's a new one on me Jason. Never encountered that problem. Perhaps, hopefully someone will jump in here who has knowledge of that problem."
  6. #6
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "It might be caused by voltage
    "It might be caused by voltage fluctuations. Running at low rpm's the charge is next to nothing. If a sudden load is put on the battery, this might happend (pump starts or similar). Check all battery, B+ and ground connections both at engine, horn and instruments. If it happends again, the alarm should disappear by pressing the bulb (do not shut off the engine). If not an electrical'fault'as mentioned above. It might even be in the VRO electronic unit itself in which case the VRO has to be changed. The 4th wire that was added quite some years ago to the VRO alarm system was to prevent this from happening."
  7. #7
    Jason U's Avatar
    Jason U Guest
    Default "Guys, Thanks for all your
    "Guys,
    Thanks for all your input. I will let you know how it turns out onec it gets fixed!
    Jason."
  8. #8
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,812
    Default "bubbles,due to an air leak in
    "bubbles,due to an air leak in oil line will also cause this,you might ck the oil hose conn."
Similar Threads
  1. 235 johnson alarm
    By lonferg in forum Johnson Evinrude Outboard Archive
    Last Post: 09-02-2009, 08:48 PM
  2. 88 Johnson SPL Alarm
    By tsanders in forum Johnson Evinrude Outboard Archive
    Last Post: 08-01-2009, 10:50 AM
  3. Johnson 150 alarm activating
    By ff92 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-09-2009, 09:08 PM
  4. 1993 johnson 150 oil alarm
    By jordan holmes in forum Johnson Evinrude Outboard Archive
    Last Post: 09-04-2008, 09:42 PM
  5. Alarm 90 hp johnson 1993
    By rmike72pu in forum Johnson Evinrude Outboard Archive
    Last Post: 09-03-2007, 04:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
