thudpucker
"Evinrude 3034-07794 (I
"Evinrude 3034-07794 (I've been told it's a 1960 Folding shaft)
This little guy will start and run fairly easy.
Starts every time on the first pull or two.
When the throttle is wide open it sounds like it's only running on one cylinder.
But both plugs fire when I'm pulling it through with the plugs grounded to the block.
When I let it back down to Idle it just dies.
Fast Idle is erratic. Speeds up n' slows down.
Why is it so erratic? What am I missing?
It has the old Needle n' Seat. I couldn't find a kit with a new set included. The carb is clean and all passages are clean and open.
The kit I have, has new cork seals, which I used.
The float seems to work well.
The Float is set perfectly parallel to the Carb assy.
When I got the motor, one coil did not work. The Terminal end that connects to the points was twisted off. Only the insulation was connected to the Coil. I put a new Terminal end on.
One plug wire has a Metal ring squeezed on it. I'm gonna assume that's the Upper plug wire.
Will it run with those plug wires reversed?
This little bugger is beating me to death!"
