95 70hp force #2 cylinder not firing
cbrown7142
"I have a 1995 70hp force only
"I have a 1995 70hp force only runing on two cylinders, #2 cylinder is not firing. Checked compression 120lbs in all three cylinders, checked coils all three are firing, checked plugs all three are good, #2 plug comes out wet. Anyone know what the problem could be? Thanks"
"you say #2 is not firing, but
"you say #2 is not firing, but u re getting spark on all three, how is that?"
"That is what i am asking, I h
"That is what i am asking, I have changed the coil packes from #1 and #3 to the #2 cylinder everything is firing outside the cylinder of #2 but when the plugs are re installed, i can pull the plug wire on #1 and it bogs the engine down, i pull the plug wire on #3 and it also bogs the engine, however when the plug wire is pull off the #2 cylinder it does not faze the motor in any way,(runs the same as if it was still pluged on) any futher ideas?"
