1974 15hp wont start
ctizz
"I recently bought a boat with
"I recently bought a boat with a 15 hp evinrude. Fixed the spark problem, gas is going to carb, and has compression. But still cant get it to start. Any
suggestions?"
"is the choke operating ok....
"is the choke operating ok....closing fully?.......if this engine has sat a looong time,there is a poss of reed valves sticking...there is also the poss of having spark,but .w/a sheared/displaced flywheel key,therefore throwing off your ignition timing,allowing you to pull your arm out of the socket!"
I double checked the compressi
I double checked the compression and both cylinders have 90 psi after four pulls.
What is really bothering me is that its doesn't fire at all.
