275 bellows change
shawnmor
Hello All
i am trying to chan
Hello All
i am trying to change the drive bellows and universals on my AQ131A with a 275d outdrive
The Seloc Manual is not clear to me
Any help and advice would be greatly appreciated
Thank You in advance
Shawn
From the Lakes of Muskoka
"To remove the drive bellows,
"To remove the drive bellows, first loosen the clamps 67 and 68, then unbolt the upper gear assembly and remove it from the rest of the outdrive (drain oil first); afterwards, remove the Allen bolt 33 so that you can remove the universal assembly. After you have removed it, change the spiders.
http://www.dougrussell.com/partscatalog/volvo_omc/index.cfm?fuseaction=comp&grou p=1921&GroupList=1923,1922,1899,1901,1902,1903,1904,1900,1924,1905,1906,1907,190 8,1909,1910,1925,1926,1911,1927,1912,1913,1914,1915,1916,1917,1928,1929,1930,193 1,1932,1939,1919,1934,1935,1920,1936,1921,1937,1938,1940"
