MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2007
    Location
    Swanton, Vermont, USA
    Posts
    12
    Default "All carbs. fuel pump just reb
    "All carbs. fuel pump just rebuilt. Runs real good but needs to Idle down. I have a problem finding how to complete this task. I went to Seloc on line and it says to turn screw on bracket, I turned the screw no change on the Idle.May I be missing something. Can someone help me out.
    Thank You"
  2. #2
    not-a-student's Avatar
    not-a-student Guest
    Default You may need to adjust the cab
    You may need to adjust the cable at the motor to pull the arm against the idle stop screw.
  3. #3
    Join Date
    Apr 2007
    Location
    Posts
    12
    Default The cable at the motot which o
    The cable at the motot which one would that be??Should the screw be turned in or out?I'am not very good at this but thought I could handle a easy task as this.
    Chris1956's Avatar
    Chris1956 Guest
    Default "Terrance, Depending on the ye
    "Terrance, Depending on the year, the 115 HP mercs were a bit different. There may be a screw marked "Idle Stop". If so, the throttle should be pushed against the screw, when the motor is in neutral. If not, you can adjust the throttle cable barrell nut to push the throttle against the stop. You may also back off the idle stop screw a bit to lower the idle speed, in conjunction with adjustment of the throttle cable barrell nut."
Similar Threads
  1. Where is idle adjustment on a new 2010 4 stroke 6 HP Mercury
    By adjuvantjfoster in forum Mercury Mariner Outboard Forum
    Last Post: 09-16-2010, 09:26 AM
  2. Idle Adjustment
    By silvertrac51 in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-07-2009, 09:29 PM
  3. Idle adjustment
    By tboltmike in forum Johnson Evinrude Outboard Archive
    Last Post: 11-15-2007, 07:02 PM
  4. 50 HP Mercury Idle adjustment
    By rainman5 in forum Mercury Mariner Outboard Archive
    Last Post: 07-26-2007, 10:13 PM
  5. Idle adjustment on 1975 Mercury 40 hp
    By Paulette Carpenter in forum Outboard motors archive 2000-2004
    Last Post: 07-29-2001, 07:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
