MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
  1. #1
    Join Date
    Apr 2007
    Location
    roanoke, va, us
    Posts
    16
    Default "I have had my boat in the rep
    "I have had my boat in the repair shop for the past couple weeks because It was having trouble starting and idling. I got it back last weekend and they said they replaced the starter, replaced the floats, cleaned all 3 carbs and adjusted the idle.
    I took it out last week end and it started up great and Idled great. However when I give it some throttle and it goes into gear it stalls, If I ease the throttle into place I can get it to go maybe 5-10 mph but any more throttle and it dies. While I was idling at 5-10 mph another boat passed me and as their wake shook my boat something just kicked in and my boat started working normally and could cruize just as fast as normal when I brought the engine back to neutral and tried to give it more throttle once again it stalls. I couldnt get it to go back to normal after that. I brought the boat back to the repair shop, but I was curious if you guys would know what was wrong."
  2. #2
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default "floats or not adjusted right
    "floats or not adjusted right or a loose wire connections, or even the trigger base is not moving if u have that kind of trigger"
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  3. #3
    not-a-student's Avatar
    not-a-student Guest
    Default "Sounds like it is set too lea
    "Sounds like it is set too lean and you need to adjust the three low speed jets (upper right on the carburetor ) Open up all three 1/8th turn at a time and try again.It is common to set them up lean as it gives nice idle, but like you have found out they need extra fuel to get between idle jet and high speed jet."
  4. #4
    Join Date
    Apr 2007
    Location
    roanoke, va, us
    Posts
    16
    Default "thanks, I'll keep you pos
    "thanks, I'll keep you posted on what it is, It sounded like it was fuel related so I think it's just set up too lean the repair shop BETTER fix it for free since it was their mistake!"
  5. #5
    Join Date
    Apr 2007
    Location
    roanoke, va, us
    Posts
    16
    Default "ok, the shop thinks it's
    "ok, the shop thinks it's the stator what do you guys think?"
  6. #6
    not-a-student Guest
    Default Have you tried to adjust the i
    Have you tried to adjust the idle mixture ????? If it is the problem you can give yourself a pat on the back and you can then inform the shop that you are not impressed with their work.You may not have a problem again with them when they realize that not everyone is " motor challenged "
  7. #7
    Chris1956's Avatar
    Chris1956 Guest
    Default "Brad, It is likely you need
    "Brad, It is likely you need to richen the carb idle mixture. To do this, warm up the boat in the water. Now open (CCW) the top carb idle mixture screw 1/8 turn, and try to accelerate. Repeat with mid-carb, and then bottom carb. Try to accelerate betwen each adjustment. Repeat top-mid-bottom carb sequence if necessary. Stop adjustments when the motor idles reasonable well and accelerates well."
  8. #8
    Join Date
    Apr 2007
    Location
    roanoke, va, us
    Posts
    16
    Default "hey guys, I got my boat back
    "hey guys, I got my boat back today with a new stator and took it out, same problem... I have not tried adjusting the idle mixture because I was worried I would turn the wrong screw and not be able to get it back to normal. I did learn a little trick that enabled me to get it running well, if I tap the choke while I accelerate it seems to go perfectly fine. To me it sounds like the air fuel mixure must be incorrect as you guys have mentioned, can you explain to me exactly what screws I need to turn while I am in the water, LOL I will even take a picture of my carburator if that would make it easier for you guys to explain. And it should still be top-middle-bottom correct? I really appreciate you guys help you've treated an inexperianced newbie well."
  9. #9
    Join Date
    Apr 2007
    Location
    roanoke, va, us
    Posts
    16
    Default "lol I checked the manual of a
    "lol I checked the manual of all places and it gives me a picture, I'll go out today to adjust it"
Similar Threads
  1. 1983 Mercury 70 HP stalls under load
    By Emerson2 in forum Mercury Mariner Outboard Forum
    Last Post: 11-05-2010, 07:09 AM
  2. 2004 90hp Johnson, stalls under load
    By steve6078 in forum Johnson Evinrude Outboard Forum
    Last Post: 07-08-2010, 01:47 PM
  3. Mercury 6HP 4 stroke stalls under load
    By davedylan in forum Mercury Mariner Outboard Archive
    Last Post: 06-26-2008, 08:32 PM
  4. 1978 90hp mercury inline 6 power trim problems
    By bradccool in forum Mercury Mariner Outboard Archive
    Last Post: 05-20-2007, 10:25 PM
  5. 1988 mercury 1500 150hp inline seems to load up on acceleration
    By Anthony Minton in forum Mercury Mariner Outboard Archive
    Last Post: 05-17-2004, 10:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
