J
joe meyers sav
Guest
"Just bought this motor a few
"Just bought this motor a few weeks ago. Had a problem with it idling. When trying to put it in gear, it would die. Raised the idle to 900 rpm in the water.It idles at 1100 out of the water. Yesterday, I noticed when I would start the motor it would idle at 900, then slowly drop to 700 or so and die when puting it in gear.Restart and it idled at 900. It then ran good the rest of the day.When I got home, I lowered the motor to flush it. A gas trail is seen running down the outdrive. All the plugs are wet, but not drenched. The VRO is disconnected. Anyone having similar problems? Suggestions? Also, where is the model and serial number located? Thanks!"
