Rough idle Evinrude 33 hp 1996
victor
"I have purchased this motor t
"I have purchased this motor this winter. It look like new. But, in a tank test, the idle is very rough. New plug and fresh gas. No idle needle for this motor. Someone have a suggestion?
Excuse my english....."
"If you have compression and s
"If you have compression and spark, suspect that the carburetor is somewhat fouled due to sitting."
I changed the throttle jet ne
I changed the throttle jet needle adjustment. Normaly the little clip is in third groove. The setting is in fourth position. I changed the clip and i'm tested the motor. It run great now...
