Oil Filter Oil Capacity Fuel Filter amp Lower Unit Capacity
bggolfr1
I have a 1997 5.7L V8 350 Merc
I have a 1997 5.7L V8 350 Mercruiser with an Alpha One drive:
1) What is the correct oil filter?
2) What is the oil capacity?
3) What is the correct fuel filter?
4) What is the lower unit gear oil capacity?
I can't ever remember these specifics each season... I need to write them down.
"Your dealer will be able to s
"Your dealer will be able to supply all the right parts and quantities, or it should all be in your operators manual."
"1) Depends on whether it&
"1) Depends on whether it's Engine Mounted, or Remotely Mounted......
2) Probably 5qts... Might be 6qts. though.....
3) Get the # off Your's,.... There's several.....
4) About a Qt.+ 1/2....."
