88 GM350 Swap with 79 GM350
willy
" Can Any one help?I have 1988
" Can Any one help?I have 1988 GM350 with a OMC cobra drive eng.is going bad I have a chance to buy a rebuilt 79 GM350. Will the 79 swap over with no problems.Any help would be appreciated.
Thank You,
Willy "
Bellhousing should be the sam
Bellhousing should be the same ALong with the mounts & everything. The only thing I know is different is the oil dip stick is on the opposite side of the engine
" If you need any help or part
" If you need any help or parts to put it together you can give me a call at 1-800-748-7739.
I dont know how much of the engine youve purchased, but I can tell you that the oil pan, flywheel, coupler and intake manifold is different.
good luck,
Gabriel Acher, Dania Marine Corp. "
good luck,
