Results 1 to 6 of 6
    bruce raykos's Avatar
    bruce raykos Guest
    Default " Hi I have a 83 merc , 120 hp
    " Hi I have a 83 merc , 120 hp merc, when I get past the no wake zone and open it up it dies. the carp it open , fuel is from a external tank for now.fuel filter is new and have also did rebuild to carb, any more info let me know, thanks bruce "
    croozertoo's Avatar
    croozertoo Guest
    Default "Hard to say exactly where it&
    "Hard to say exactly where it's happening, but it sounds like fuel starvation. Ignition advance is also suspect. Are you gettng a full "shot" from the accelerator pump? Will the engine rev in neutral without bogging?
    [img][/img]"
    egyptbruce's Avatar
    egyptbruce Guest
    Default " engine does rev in nrtrual b
    " engine does rev in nrtrual but buld in gas line goes dry, I just repalced fuel pump and want to try it out soon hope this does it. "
    egyptbruce's Avatar
    egyptbruce Guest
    Default " by replacing fuel pump. it n
    " by replacing fuel pump. it now works, thanks for your info. bruce "
    poker casino775's Avatar
    poker casino775 Guest
    Default "***** ****** [url=""]***** 71
    "***** ****** ***** 710"
  6. #6
    Default Re: Starts idels then dies as power is applied
    Im new here i have a 70 Johnson 115 seahorse. It runs great out of the water but when its is in the water i have to keep the choke pushed in at all times when i am at full throttle can any one help me ?
  1. 1992 70 force DIES WHEN THROTTLE APPLIED
    By FISHING72 in forum Miscellaneous marine engine topics
    Last Post: 07-09-2008, 10:10 AM
  2. Engine dies but starts up again
    By jb914 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 06-03-2008, 10:04 PM
  3. Cranks starts dies
    By wharfcreek in forum Volvo Penta Gas Archive
    Last Post: 04-13-2008, 04:43 PM
  4. Crusader 454 starts and dies
    By clinton in forum Crusader Marine Archive
    Last Post: 12-17-2006, 06:19 PM
  5. New 50 mpi breakin time before full power is applied
    By bob Fender in forum Archive 2003-2009
    Last Post: 03-20-2004, 08:59 PM
