Page 1 of 3 123 LastLast
Results 1 to 30 of 62
Thread: Tomos Outboard
  1. #1
    Default " Hi Lads, Have purchased a T
    " Hi Lads,
    Have purchased a Tomos 4HP outboard motor. Unit was made in Yugoslavia
    Details model T4S Engine No 316009 made in 89.
    Afraid the book I have does not give any information on how to set the points just gives the gap as 0.35-0.45mm and ignition advance as 1.5+0.1mm BTDC can anybody help with the set up procedure.
    Also Carb only has one screw any ideas on how to set it correctly.
    Thanks.
    Brian "
  2. #2
    Finch101's Avatar
    Finch101 Guest
    Default Glad to see I'm not the o
    Glad to see I'm not the only person that has purchased a Tomos? (motor) would you know how I can go about finding parts for a Tomos Traveler 18hp.I need the little wheel on the crankshaft that goes up and turns the flywheel the teeth on mine is worn down.
  3. #3
    Default "In the UK we only have one de
    "In the UK we only have one dealer who has parts
    Do not know who he is yet but if you contact
    [email protected] he maybe able to supply the part.
    Know he will supply a manual if required.
    Seems info is difficult to obtain on this outboard.
    All the best,
    Brian"
  4. #4
    Aled Griffith's Avatar
    Aled Griffith Guest
    Default I believe the main importers
    I believe the main importers for the Tomos engines were
    SeaPage International
    Tel: 01929 551 406
    I have a Tomos T10 10HP outboard anyone know where I can get hold of a manual as the water cooling is not working?
    I purchased some parts three years ago so the information may be out of date good luck!
    All the best
    Aled
  5. #5
    Default " Aled, Yes, you are correct
    " Aled,
    Yes, you are correct its still the main dealer.
    For a price he will also supply a blown up parts list which should help to locate the problem.
    Brian "
  6. #6
    Bradley Turvey's Avatar
    Bradley Turvey Guest
    Default "If anyone knows where to get
    "If anyone knows where to get parts for a Tomos motor could they E-Mail me at [email protected] , or if they would have the part, it is a little plastic piece inside the throttle handle that makes the engine go."
  7. #7
    Default if anybody out there knows of
    if anybody out there knows of a parts source for a TOMOS TRAVLER 9.9 I have chewed-up teeth on the starter gear. I have to wrap a cord around the flywheel to get it cranking. thanks-JIM
  8. #8
    Jim Ferrio's Avatar
    Jim Ferrio Guest
    Default "P.S. Jim here, with the chewe
    "P.S. Jim here, with the chewed teeth forgot to offer my e-mail for any [email protected]"
  9. #9
  10. #10
    ed schmitt's Avatar
    ed schmitt Guest
    Default "Does anyone know where I can
    "Does anyone know where I can get another lower unit plug for a Tomos Traveller 9.9. I believe it is a 1cm x 1cm x1.0 pitch. Contact me at [email protected]. Many thanks, Ed Schmitt"
  11. #11
    Tim Haley's Avatar
    Tim Haley Guest
    Default "I too have a Tomos and strugg
    "I too have a Tomos and struggle to find parts. many inquiries above but do not see any positive responses?
    I have a 4 hp 1988 nd the gas tank has become porus and cracked on the corners leaking when not in the upright position. Any ideas? [email protected]"
  12. #12
    Wayne Evert's Avatar
    Wayne Evert Guest
    Default Can anyone tell me where I can
    Can anyone tell me where I can buy a new shifter for my Thomos motor?
  13. #13
    bob sarrocco's Avatar
    bob sarrocco Guest
    Default "Tomos 18hp engine for sale. C
    "Tomos 18hp engine for sale. Contact [email protected]"
  14. #14
    Benh23's Avatar
    Benh23 Guest
    Default "I have a tomos 9.9 travler ru
    "I have a tomos 9.9 travler runs good but i have a bad impeller and am in the process of finding a new one, yamaha has some that are very similar..."
  15. #15
    Default i have tomos 4 hp parts for sa
    i have tomos 4 hp parts for sale
  16. #16
    Default "Hello, You can find Tomos
    "Hello,
    You can find
    Tomos Outboard:
    - spare parts
    - Repair, Service Maintenance Manuals
    here in the online shop
    http://www.tomos-aussenborder.de"
  17. #17
    Join Date
    Oct 2007
    Location
    woodstock, new york, usa
    Posts
    69
    Default looking for pinion gear in low
    looking for pinion gear in lower unit for tomos 18hp. any ideas? thanks bill
  18. #18
    brandon inman's Avatar
    brandon inman Guest
    Default "I have got a 1987 Sportsman T
    "I have got a 1987 Sportsman Tomos 9.9 but in need of an impeller. It's a very sharp motor picked it up for 200.00,if anyone can help please send me an e-mail"
  19. #19
    Join Date
    May 2008
    Location
    Ripon, n,yorks, uk
    Posts
    1
    Default "Im requiring help as i have a
    "Im requiring help as i have a Tomos 4hp and im looking for a connector from the fuel pipe to the engine if anybody knows where i can get one would they please mail me [email protected]"
  20. #20
    Join Date
    Jun 2008
    Location
    flamborough
    Posts
    1
    Default "Hi, got a aisla craig , tom
    "Hi, got a aisla craig , tomos 4hp outboard, starts fine and revs fine but when i put it in the water the prop doesnt turn any faster no matter how high i rev, as if something is slipping, any ideas?, I can even stop the prop turning with my foot and rev the engine?"
  21. #21
    Mokus Gabor's Avatar
    Mokus Gabor Guest
    Default "Your problem might be that th
    "Your problem might be that the small security rod is broken, or broken and jammed in. It is found bellow, at the prop. You have to take down the black cover (at the end of the propeller), and there has to be a small approx. 3 mm. thick metal rod that is actually connecting the prop and the drive. If that`s missing or is broken, there is no connection between the prop and the engine and the prop turns only because of friction...
    I hope I helped!"
  22. #22
    alexander webb's Avatar
    alexander webb Guest
    Default Need to find prop for a 4.5 hp
    Need to find prop for a 4.5 hp tomos outboard engine if you have info on this part please contact me at the e-mail address listed below.}
  23. #23
    Join Date
    Dec 2008
    Location
    , ayrshire, scotland
    Posts
    62
    Default hi can anyone give me informat
    hi can anyone give me information on a ailsa graig 4hp outboard ie fuel mixture common faults
    starting tips ect
  24. #24
    Join Date
    Jul 2009
    Location
    Pittsburgh, PA, USA
    Posts
    7
    Default I have a 4 HP Tomos Travler &#
    I have a 4 HP Tomos Travler (model T4S) that run fine for about 15 min's then stops. Wait for 15 min's and it starts and runs again for 10 min's then stops again. Have replaced all ignition parts and fuel related items to no avail.
    Starting to think it's vapor lock.
    Anyone experienced the same symptoms?
  25. #25
    Default "I have a Tomos T4 which runs
    "I have a Tomos T4 which runs fine. However, when full throttle is applied, it will run at full throttle for a few seconds before going back down to half throttle, with full thottle still applied.
    Anyone know what the problem is?"
  26. #26
    Join Date
    Dec 2008
    Location
    Posts
    62
    Default hi to all you tomos owners i b
    hi to all you tomos owners i bined a 4hp ailsa graig couple of weeks ago as i could not find parts for it i i had known someone had a use for it they could have had it
  27. #27
    Join Date
    Jul 2009
    Location
    Pittsburgh, PA, USA
    Posts
    7
    Default "Wow!!! Ian, I will take you
    "Wow!!!
    Ian, I will take you up on your generous offer.
    However, I am not sure how to get it to Pittsburgh, PA from Scotland?"
  28. #28
    Default He didn't offer it. He sai
    He didn't offer it. He said he had just thrown it away!!
  29. #29
    Join Date
    Jul 2009
    Location
    Pittsburgh, PA, USA
    Posts
    7
    Default Tomos 4 HP (T4S) FIXED
    Tomos 4 HP (T4S) FIXED!!!!!
    I recently received a email from a fellow from Denmark telling me to check the sparkplug cap on my Tomos 4 HP outboard.
    He had the same outboard and His sparkplug cap shorted the high voltage after running for 10 min's then would run again after cooling down.
    I replaced my sparkplug cap (even though it looked perfect) and now the Tomos runs great!
    Folks in Denmark and this forum rocks.
  30. #30
    Default "was anyone ever able to find
    "was anyone ever able to find some place to get Tomos parts i have a T-3-S and could use any info i can get my e-mail is [email protected] thanks"
Similar Threads
  1. Tomos 5 HP
    By springbok74 in forum Tomos Outboards
    Last Post: 11-24-2012, 01:29 PM
  2. Tomos
    By xrs080 in forum Tomos Outboards
    Last Post: 09-17-2008, 04:23 AM
  3. Tomos Outboard
    By ttucker in forum Tomos Outboards
    Last Post: 08-04-2006, 11:04 AM
  4. Tomos outboard motor
    By sven in forum Outboard motors archive 2000-2004
    Last Post: 06-20-2002, 07:58 AM
  5. Need Info on a Tomos outboard
    By jason games in forum Outboard motors archive 2000-2004
    Last Post: 03-07-2002, 10:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
