D
dan tuinstra
Guest
" 93 merc three cyl. tiller,
" 93 merc three cyl. tiller, LS, TT, oil injected. So far I have relaced every gas line and fitting from the tank(new) to the fuel pump. I saw air bubbles in the plasitc T right before the fuel pump that appeared to be coming from the fuel line not the oil sender. So I took the fuel line off at the cowling ( so that there was only fuel line to the fuel pump T, which was about 12" of line) and dropped it in a cup of gas, trying to eliminate any thing from there to the tank, same results air bubbles... idles down and dies...
I have a rebuilt kit for the fuel pump, but I replaced it 2 years ago. to no avail.
It has had this problem for some time, I troll with the motor and therefore it is at idle a bunch. If I take my had of the tiller handle, it drops RPMS and dies. If I pump the bulb it will continue to run or if I pump the tiller trottle handle by rotating to more gas a couple of times.
At HIgh RPM (WOT) right after I get on plane, the motor will occasionally die until the bulb is pumped then it will run fine forever at WOT.
Thanks in Advance! It has me stumped!
dan "
dan "
