P
paul casteel
Guest
I have a 1996 Johnson 150 Fas
I have a 1996 Johnson 150 FastStrike motor with a starting problems. Some days you can go out and turn the engine over and it will start on the first try. The next time you try to start it you will get no response. The first attempt at repair I changed the kill switch. I just replaced it because someone had put but splices to wire it in. One wire on the blk/yel and one to blk/wht. I have soldered these in and added heat shrink. The next attempt was on suggestion from OMC dealer and I replaced the iginition switch with a new one. He said that mine had the white paint so it should have not been the problem switches from the problem erea. I also had evidence of the blk/yel and the yel/red wires in the disconnect for the switch being burnt. I reterminated these with a Amphonal military water tight connector to no avail. I tried to start it and it did its favorate no starting trick. After about 20 trys the engine did fire. We questioned the power pack but the problem usualy only happens when the first start of the day. I have had the engine after the first start die on the first throttle up and not start immediatly there after. Once you get the first start for the day it does not seem to have a problem starting the rest of the day. I have pulled the plug wires off when it would not start and appears not to have any fire. The engine does to appear to miss (spits) occasionaly when just idling around with no throttle imput. We just can not verify the problem as such as if it won't fire on the lake by the time I can drive five miles to the nearest shop it will start no problem even with three cyclinders unpluged on a spark tester. If anyone has any ideas I would appreciate it. I missed a trip today and I have a three week waiting period before I can get it in the shop. Thanks
