" 35 hp evinrude 1957 #25532,
" 35 hp evinrude 1957 #25532, no bubble's in fuel line (used to be), new gas and air lines (2 line system,)adjusted mixture screws runs like a champ in the pail (in gear)forward and reverse . but when i put it in the water it doesn't want to run right . starts to kick at low idle so i adjust the top mixture screw so it runs good then it starts to kick again after a couple of minutes and have to put the mixture screw back to where it was then it runs again. at wide open throttle , it takes off good planes out then falls on its face, then goes like a mother, then falls on its face (go , stop , go , stop).i think i might have the float set wrong but can't find any information on it, as to what to set it at or what the setting should be. could this be my problem and would you know what it is to be set at.
thanks for your help. "
