Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 3 of 3
  1. #1
    Tom Morton's Avatar
    Tom Morton Guest
    Default When turning ignition motor d
    When turning ignition motor does not even 'cough'--just spins. Same with throttle open---will spin several times then with throttle fully open will fire and run. Stops and restarts fine as long as it is not a long interval. Leave it 15 mins or more and problem repeats
  2. #2
    Default choke enricher valve must wor
    choke enricher valve must work or carb mercs won't start. push key in or seperate switch. solenoid clicks on brass thing by carbs if working
  3. #3
    Join Date
    Nov 2005
    Location
    Posts
    89
    Default check the enricher valve
    check the enricher valve turn all the way clock wise wait 4 seconds then reclose by turning opposite way
    hope that can help
    john
Similar Threads
  1. Mercury 150 Hard Start when Hot
    By gatorman in forum Mercury Mariner Outboard Archive
    Last Post: 08-03-2009, 08:35 AM
  2. 1996 Mercury 115 Hard To Start
    By Bryan Barr in forum Mercury Mariner Outboard Archive
    Last Post: 08-12-2008, 12:51 PM
  3. 2000 Mercury 150hp V6 Canbt Start
    By deeflat in forum Mercury Mariner Outboard Archive
    Last Post: 04-24-2008, 12:49 PM
  4. 2001 Mercury 90 HP Hard Start Hesitation
    By mercranker in forum Mercury Mariner Outboard Archive
    Last Post: 04-14-2004, 09:25 PM
  5. 82 150hp V6 Mariner Hard Start No Idle
    By Chris Noah in forum Outboard motors archive 2000-2004
    Last Post: 06-17-2002, 09:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
