Results 1 to 3 of 3
    BRUCE GOODSITE     's Avatar
    BRUCE GOODSITE Guest
    Default " HAVE BEDFORD 466 LONG BLOCK
    " HAVE BEDFORD 466 LONG BLOCK COMPLETE EXCEPT FOR ALTERNATOR, STARTER, INJECTION PUMP AND LINES. ENGINE CAME FROM FACTORY SHOW ENGINE USE. WAS NEVER RUN EXCEPT FOR RUN-IN AT FACTORY. ALSO HAVE USED HEAD AND HEAT EXCHANGER, AND NEW B/W 1to1 GEAR. "
    Jun 2000
    Forest Dale, VT, USA
    1,681
    Default "Bruce, You should post thi
    "Bruce,
    You should post this as a classified ad in our classifieds section.
    Thanks.
    Andrew Menkart
    [img][/img]"
    Andrew Menkart
    MarineEngine.com
    "There is no situation in which knowledge is more truly power than at sea."
    - Lord Brassey
    Default Re: " HAVE BEDFORD 466 LONG BLOCK
    Just a shot in the dark, but do you still have this motor and parts?
    Thanks,
    Josh 714 658-0002
  1. First Mate Long Block
    By sammi in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 02-06-2010, 11:04 AM
  2. New long block or Rebuild
    By amantinori in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 12-16-2009, 11:51 AM
  3. Long block etc
    By deltadog in forum Crusader Marine Engine Forum
    Last Post: 09-16-2009, 04:40 PM
  4. 350 OMC LONG BLOCK
    By will_parker in forum OMC Sterndrive and Inboard Archive
    Last Post: 12-01-2007, 07:15 PM
  5. Replace 43 with long or short block
    By chris_f in forum OMC Sterndrive and Inboard Archive
    Last Post: 02-09-2007, 07:38 AM
