Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 3 of 3
  1. #1
    chris saul's Avatar
    chris saul Guest
    Default "good compression: 130,130,125
    "good compression: 130,130,125,122, #3 cyl. not firing right. It has plently of spark, and when wire is off runs smooth. Has not been run for one year, is the bottom carb gummed up? Why does the #4 cyl run ok? Many thank for input, Chris
    [email protected]"
  2. #2
    Join Date
    Feb 2002
    Location
    Posts
    59
    Default maybe the number 3 plug is fo
    maybe the number 3 plug is fouled ?
    any cracks breaks etc in the wire ?
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    15,904
    Default "Chris..... Mercurys are not m
    "Chris..... Mercurys are not my line of expertise, however when a engine sits for that length of time, it is very common for the carburetors to become fouled. I'd suggest strongly that you remove, clean, and rebuild all of the carburetors before running the engine again.
    Joe (30+ Years Wihth OMC)"
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. 1996 Mariner 50HP 4 cyl4 stroke uneven compression
    By kayem in forum Mercury Mariner Outboard Archive
    Last Post: 07-23-2009, 02:39 AM
  2. Good compression on a 115 4 stroke
    By reelnative in forum Yamaha Outboard Archive
    Last Post: 05-24-2009, 08:09 PM
  3. Compression Good What next
    By jamiel in forum Johnson Evinrude Outboard Archive
    Last Post: 09-28-2008, 12:13 PM
  4. What is good compression on a 150 johnson
    By jerry wood in forum Johnson Evinrude Outboard Archive
    Last Post: 08-02-2008, 03:51 PM
  5. 85 Ev compression good now what
    By jeffjohnson in forum Archive 2003-2009
    Last Post: 04-25-2004, 08:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
