"hi all -
I have a 1989 1
"hi all -
I have a 1989 175 Johnson.
I have 2 fuel tanks connected to a t-piece switch, then to an electric fuel pump - through a filter to the motor. - All fuel lines and breather lines have been replaced & tanks cleaned.
My Problem is - the motor idles well & goes great at WOT, however when i have been going for 4-5 minutes under load - it powers down to a stop or an idle - starving the motor for fuel. The primer bulb to the respective tank gets sucked in and cannot be primmed.
When tanks are switched - the same happens however, the 1st tank's primer returns to full.
I have checked the filler line filters on both tanks & the main filter and all is clear. I have run with the fuel caps off and this problem still occurs.
Any assistance would be greatly appreciated.
thanks in advance"
I have a 1989 1
"hi all -
thanks in advance"
