MR 165 BELL HOUSING amp GIMBAL RING
oldboy
"I have not found the informat
"I have not found the information in ether the Mercruiser repair manual or the SELOC manual.
What Im looking for is a spec. or tolerance on the Hinge pins and there bushings.
If you grab onto the Bell housing and move it side to side. I get a little movement.
If I grab and move bell housing up & down its solid,no movement. So how do you tell if the Hinge pins & Bushings need replaced?"
