"Terrance, That motor calls f
"Terrance, That motor calls for a 5/16" fuel line, however, I would use a 3/8" fuel line to be sure it gets enought fuel. As for your running issue, have someone pump the primer bulb at high speed, and see if the problem goes away. If the problem dissappears, make sure the fuel filters and screens are clean and the tank vent is open, and then rebuild the fuel pump.
If the problem persists, it is likely due to dirty or clogged carbs. These need to be removed, cleaned and new gaskets and inlet needles be installed and adjustment of the idle mixture."
