Prop clicker
bojangle
"When I spin my prop, there is
"When I spin my prop, there is a definite clicking noise....what do you think is problem ? I just changed that prop.."
"It's Probably the Dog-Clu
"It's Probably the Dog-Clutch.....
When In Gear, it should Turn, with Clicks 1 way,+ Not the Other.....
In Neutral,.... There should be No Clicking..... If there Is, Your shift Cable is Out of Adjustment......"
"It turns both ways, even in g
"It turns both ways, even in gear, tho there is some resistance one way...(the wrong way).. and clicks in all positions even neutral... I also had some problems with the kill switch, and disabled the contact on the transon where it goes into the notched out U... does that all sound like shift cable ... adjustment or replacenment ?"
"Ayuh,......
I'd Replac
"Ayuh,......
I'd Replace the Lower Shift Cable for Starters.....
And,....
Get that Shift Switch hooked back Up,....
That alone withh Stretch,+ Destroy the Lower Cable......"
"Thanks Bondo..Going to tear d
"Thanks Bondo..Going to tear down the outer unit at the same time.. Hey here's a question for you.. My leg is a Mercruiser 1..is that the same as an Alpha...being a newbie, just haven't figured all that out yet ?"
"It's the predecessor to t
"It's the predecessor to the Alpha,.....
Close,... But Slightly Different......."
