"Robert: I don't have the
"Robert: I don't have the year manual you have so I was going on the premise it is similar to my 1987 mercruiser. The wiring is correct per your manual.
You can tell if you had a stove pipe choke by looking at the intake manifold directly under the choke. There will be either a flat oval shaped cover plate and/or one with two pinched tubes, hence stove pipes that drew heat from the exhaust crossover inside the intake manifold.
The white wire supplies the 12 VDC to the choke continuously with the ignition on. Are the white and tan wires connected at the choke? Are you running a points and condenser ignition? I believe you are since the tan wire is a resistance wire that would drop the voltage from the 12 VDC at the choke to 6 VDC at the coil. Are the points fried? See your manual. If so, replace them along with a set of plugs and set them and the timing to specs. Check the cap and rotor for corrosion and replace per the manual description.
NOTE: I would get rid of the points with an electronic conversion kit, about $50. IF YOU DO THAT, YOU MUST REPLACE THE TAN WIRE WITH A NON-RESISTANCE WIRE TO GET A FULL 12 VDC TO THE COIL.
By cutting the white wire, you don't have power to the choke or the coil--it will never start if the white and tan wires were connected in series. Reconnect the wires as they were and measure the voltage at the choke with the ignition on.
You should have 12 to 14 VDC with a fully charged battery, measure the voltage of the battery and write it down for reference. Now check the voltage at the ignition switch RED wire. It should read almost the same as the battery, less up to 1 volt. If the RED wire reads 12 to 14 VDC with the switch in the run position, then the white wire should read exactly the same. DISCONNECT THE BATTERY GROUND WIRE FOR THIS SERVICE. If the white wire reads less than the RED wire, remove and clean the red and white wire terminal ends and the switch terminals with fine sand paper and reconnect to retest. RECONNECT THE GROUND ON THE BATTERY. If the voltage reading on the white wire is not the same as the red wire, replace the ignition switch.
If all the voltages are good, adjust the choke while COLD as I stated earlier, make sure it moves freely. If not, squirt some penetrating oil on the shaft ends, remove the choke and see if it loosens. If the butterfly moves freely without the choke, the shaft is good. If you reattach the choke and it binds again, replace the choke and adjust it to specs.
Before starting the engine, hold the choke open while cold with the ignition off and pump the throttle with one long continuos stroke and see if you have fuel squirting in the air horn like a double barrelled squirt gun. If you see the squirt fuel, your accelerator pump is working. Now see if it will start. MAKE SURE THERE IS WATER RUNNING FROM A HOSE TO THE INLET MUFFS OR YOU WILL COOK THE IMPELLLER IN THE OD.
Guy"
