monterey262
"There doesn't appear to b
"There doesn't appear to be any timing marks on my engine just one notch cut in the timing tab. Can I assume that when the pulley mark lines up with the notch it is TDC, 0 degrees? I know the ECU adjusts the timing but do I set the base timing at TDC with the service mode on with the scan tool?"
