"I have an ongoing problem wit
"I have an ongoing problem with my 1988 Mariner 60HP 3 cyl. The overtemp. alarm sounds frequently after 5-7 min. above 3000RPM. I have 5PSI water pressure from 1000-3000, and up to 8-9 PSI at WOT. Tattletail is strong and steady. If I back down the throttle when the alarm sounds, it will stop. But when I speed up, it will sound after a couple of min. I have changed water pumps several times over the years, all yield the same results for pressure and temp. alarm. I changed the sensor, but it did not change the symptom. The autoblend was removed from the boat before I purchased it, so I mix gas& oil 50:1 manually. Any suggestions?"
