200hp merc flywheel torque spec
T
TIM PINCHEN
Guest
"Gday,
I am having trouble wi
"Gday,
I am having trouble with my 1984 200hp black max.Stator shot have figured that out thanks to this board.Grouse! Problem is that the online seloc manual tells me to torque down the flywheel nut to 100ft/lb UNLESS the motor is a 74 degree v then the torque sb 125 ft/lb.Cannot find anywhere reference to 74 degree.Can anyone confirm which torque to use for this motor s/n6461140
Thanks Tim"
i have a 1988 mercury boat the
i have a 1988 mercury boat the floats a stuck in the carbuator how do i fix it
"Cawthorne, start a new thread
"Cawthorne, start a new thread, at the top of the page in BLUE, thread starter. give us hp and serial number if you can. No short cuts on carbs, remove, clean, rebuild and install."
