MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    TIM PINCHEN's Avatar
    TIM PINCHEN Guest
    Default "Gday, I am having trouble wi
    "Gday,
    I am having trouble with my 1984 200hp black max.Stator shot have figured that out thanks to this board.Grouse! Problem is that the online seloc manual tells me to torque down the flywheel nut to 100ft/lb UNLESS the motor is a 74 degree v then the torque sb 125 ft/lb.Cannot find anywhere reference to 74 degree.Can anyone confirm which torque to use for this motor s/n6461140
    Thanks Tim"
  2. #2
    Cawthorne's Avatar
    Cawthorne Guest
    Default i have a 1988 mercury boat the
    i have a 1988 mercury boat the floats a stuck in the carbuator how do i fix it
  3. #3
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "Cawthorne, start a new thread
    "Cawthorne, start a new thread, at the top of the page in BLUE, thread starter. give us hp and serial number if you can. No short cuts on carbs, remove, clean, rebuild and install."
Similar Threads
  1. Torque spec
    By lcboom in forum Mercruiser Sterndrive Archive
    Last Post: 07-29-2009, 03:14 PM
  2. Merc 800 Flywheel Torque Specbs
    By nu2boats in forum Mercury Mariner Outboard Archive
    Last Post: 03-31-2009, 04:26 PM
  3. Torque Spec
    By evinrude395vs in forum Johnson Evinrude Outboard Archive
    Last Post: 02-23-2009, 10:26 AM
  4. Torque Spec for 1972 Evinrude 18 hp flywheel nut
    By j_scott in forum Johnson Evinrude Outboard Archive
    Last Post: 10-26-2008, 04:07 PM
  5. Torque spec for plugs
    By JohnPutnick in forum Mercury Mariner Outboard Archive
    Last Post: 05-25-2007, 07:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
