"I had the motor checked out b
"I had the motor checked out by the dealer and took it out on sunday for a run, and it will not idle in water, It will however idle setting hooked up to a hose. I am sure this is how they checked it also. I was able to get it to run and it is strong at WOT and inbetween until I idle. It eventually cut off and would not crank, and luckily I had enough forward momentum to get me to the dock and rope it to the trailer, After getting it home I hooked up the hose and attempted to crank it, It took over 15 tries and it finally started and idled semi ok in the yard. WHat could be causing the motor to not idle in water but idle in the yard? Wonder why it would not refire either? I had over 400 dollars of check out and carb cleaning, compression check, lower unit serviced, they said all was well. I will be calling them back but it it disapointing on my first trip out with this boat. By the way it is a 2000 115 Johnson Ocean Pro. JVLSS115."
