43 mercruiser wonbt crank
coomablue
"Hasn't been started for a
"Hasn't been started for a month, charged battery but just get a click from the slave solenoid,? Any ideas Thanks. Wyn."
"Get a Test Light,+ Follow
"Get a Test Light,+ Follow the Power.......
It sounds like it Ain't making it to the Starter.....
You could start with Removing, Cleaning, Shiney Clean, ALL the Wiring to the Starter,+ Don't Forget to do the Grounds as Well......."
"Thanks Bondo, All leads are p
"Thanks Bondo, All leads are powered up, Looks like the starter solonoid is faulty, ill pull the starter out and test. Looks awkward. not much room to work under there. cheers."
"I would just go buy the new s
"I would just go buy the new solonoid for 15 bucks. Its good preventative maintance and will probably keep you from spending hours trying to pull your starter. If you do pull your starter, it may be wise to either rebuild or get a new/rebuilt one if you do not want to replace again. Jon"
"Thanks Jon. Ipulled out the s
"Thanks Jon. Ipulled out the starter. brushes are siezed bad. I'll clean up and reinstall, All looks ok."
