MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Results 1 to 11 of 11
  1. #1
    Default "i want to replace the water p
    "i want to replace the water pump on a 78 evinrude 85 hrs but i cant get the foot to drop i took all 5 of the bolts, i even took the shift tube loose still cant get it to drop. any ideas.
    thnku"
  2. #2
    not-a-student's Avatar
    not-a-student Guest
    Default There is one more bolt.Remove
    There is one more bolt.Remove the trim tab.And there it is.
  3. #3
    Default i cant get those bolts to budg
    i cant get those bolts to budge broke 2 sockets allready will heat help
  4. #4
    Join Date
    Nov 2005
    Location
    lockhart, texas, US
    Posts
    5,811
    Default "heat is the next step,but it
    "heat is the next step,but it may not help...rem that alum does not get red,it just melts away,and fast."
  5. #5
    Default "is there anyother way to get
    "is there anyother way to get the foot loose from the trim, if i take the side plates off that cover the motor mounts can u swing the unit up and away from the trim, these bolts are not going anywhere im afrraid i will break them off"
  6. #6
    not-a-student Guest
    Default Trim tab is above the propelle
    Trim tab is above the propeller.There is a bolt up in there.If you have to destroy the trim tab they are cheap and plentiful ( used ) at most dealers.
  7. #7
    Default i feel like such and idiot i h
    i feel like such and idiot i have had that bolt out and the other 4 around the lower section of the foot and i took the shift tube loose under the carbs but it wont budge i must be still soing something wrong it couldnt be stuck that bad could it
  8. #8
    not-a-student Guest
    Default Have you taken 6 bolts out of
    Have you taken 6 bolts out of it?????
  9. #9
    Default no only 5 2 0n each side and
    no only 5 2 0n each side and larger bolt in the tab
  10. #10
    not-a-student Guest
    Default 4 Bolts take a 9/16" wrenc
    4 Bolts take a 9/16" wrench. One bolt takes a 5/8" socket and the one under the trim tab takes 1/2" socket.
  11. #11
    Default got it off thnku so much just
    got it off thnku so much just one more question now i got it all put back together and have the earmuffs on it once it starts how long should it be before i see some water comming out of the outlets
Similar Threads
  1. Water Pump for 1978 - 150 Mercury Outboard
    By aquaholictom in forum Mercury Mariner Outboard Forum
    Last Post: 06-22-2010, 03:10 PM
  2. Changing water pump kit on a 1978 johnson 70 hp
    By jim_da_mus in forum Johnson Evinrude Outboard Forum
    Last Post: 03-08-2010, 03:58 AM
  3. 1408430 1978 140 Evinrude Water pump Query
    By kiwi_dave in forum Johnson Evinrude Outboard Archive
    Last Post: 04-22-2008, 08:43 PM
  4. 1978 evinrude 85 water pump
    By hadaveha in forum Johnson Evinrude Outboard Archive
    Last Post: 04-04-2007, 12:37 PM
  5. Water Pump Help Please 1978 sea horse 4 hp
    By willworkforlures in forum Johnson Evinrude Outboard Archive
    Last Post: 03-06-2006, 09:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
