MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Results 1 to 5 of 5
  1. #1
    Bob Mack's Avatar
    Bob Mack Guest
    Default " I have Detroit Diesel 12V71&
    " I have Detroit Diesel 12V71's in my boat. I have had problem with water in my fuel which has caused extensive damage. How can I prevent water contamination in the future? Are there filters, etc. available. Thank you for any suggestions. "
  2. #2
    Join Date
    Nov 2005
    Location
    Posts
    190
    Default " There are filters, sensors f
    " There are filters, sensors for water in fuel and a bunch of other items for your problem. Consult a good marine supply store or your local Detroit dealer for help.Good luck, Kim "
  3. #3
    Join Date
    May 2008
    Location
    Leola, Ark., Dallas
    Posts
    18
    Default there are additives which can
    there are additives which can be added to the fuel try to find out if you are getting the water in the fuel you buy do others have the same problem keep your tanks full of fuelin cooler weather to prevent any condesation in the tank
  4. #4
    Arthur1's Avatar
    Arthur1 Guest
    Default "I don't have much problem
    "I don't have much problem with water in the fuel, but I think I've figured out a way to prevent most of it from accumulating.
    Those unit injectors have to have a LOT of fuel pass through them to cool them. My 671's are specified to pump 40 gallons per hour at 2000RPM. 12V71's might well be twice that. Every bit of that fuel that isn't burned goes back to the tank, HOT! After a long run, my tank is warm enough to heat the cabin quite noticably.
    There's the rub.. as the tank cools it draws in moist outside air that is free to condense it's water in the tank above the fuel level. Happens every time you run. You can separate that water out by installing large filters with water traps, and install water sensors in them, or you can prevent most of the water entry, and avoid a lot of fungal (algie) growth in the tank to boot, if you can install coolers on the return fuel lines. I'm pondering water cooling, but they have to be really well made and of cupranickle. Still the idea of one failing and dumping that much fuel out in the sealanes scares me silly. The other idea is a fan cooled heater core.. Something like a car heater.
    Could be your fuel source too... but GM diesels with unit injectors, do pump an enormous amount of hot fuel into the tanks. Something to think about.
    Arthur arthur-ma@comcast.net"
  5. #5
    poker casino62's Avatar
    poker casino62 Guest
    Default "***** ****** [url=""]***** 41
    "***** ****** ***** 411"
Similar Threads
  1. Diesel fuel in oil
    By Roy Ericson in forum Perkins
    Last Post: 11-15-2008, 05:56 PM
  2. 1985 Volvo Penta 18hp 2cyl diesel Water in fuel lines
    By anne_rendell in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 06-19-2008, 01:03 PM
  3. Ethenol in diesel fuel
    By finatic in forum Miscellaneous marine engine topics
    Last Post: 11-10-2007, 09:22 AM
  4. Has anyone tried Diesel 911 water in diesel
    By broggerp in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 10-03-2007, 04:46 PM
  5. Old Diesel Fuel
    By thewordmerchant in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 03-22-2003, 10:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
