Results 1 to 3 of 3
  1. #1
    Jim Dunn's Avatar
    Jim Dunn Guest
    Default " Fresh rebuilt Gray 4 cylinde
    " Fresh rebuilt Gray 4 cylinder overheating at 2400 rpm's and above. The higher the rpm's,the hotter the temp. Back down and the temp decreases faster that it increased.Water pump is working good(I think/water is flowing out the exhaust)Was told that new rings will cause the motor to run hot at speed until they break in(motor has 5 hrs)Any thoughts on this one?Thanks "
  2. #2
    Peter Bowland's Avatar
    Peter Bowland Guest
    Default Flat head "47" ace ma
    Flat head "47" ace marine Chrysler.
    Thermostat gone "need new one."
    If not need bypass instructions
  3. #3
    poker casino974's Avatar
    poker casino974 Guest
    Default "***** ****** [url=""]***** 23
    "***** ****** ***** 238"
Similar Threads
  1. 1999 7.4L MPI Inboard steaming and overheating
    By duskey in forum Mercruiser Sterndrive Forum
    Last Post: 03-11-2010, 03:17 PM
  2. 57 mercruiser inboard overheating HELP
    By rossbruno in forum Mercruiser Sterndrive Archive
    Last Post: 02-15-2009, 09:49 PM
  3. Gray Marine Inboard Flathead Info
    By Mike F. M in forum Gray Marine Gas Engine Forum
    Last Post: 10-18-2007, 11:07 PM
  4. Overheating inboard
    By blueflu in forum Mercruiser Sterndrive Archive
    Last Post: 06-12-2007, 11:58 PM
  5. Merc 74 Inboard Overheating
    By mramont895 in forum Mercruiser Sterndrive Archive
    Last Post: 08-19-2006, 01:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
