" This is in addition to my Fo
" This is in addition to my Force 40 trim question below. Can the relays associated with tilt trim / up/down be miss matched & therefore not work? See my post below, but basically, my 'up' doesn't work - but, if I switch the relays around, the 'up' works, but the 'down' doesn't. So, the motor is fine - it's just a relay issue (I hope). I've replaced the bad relay with no luck. I'm wondering if I need to replace both of them? Thoughts? "
